106888 said:
how do i rplace bodymounts and busted bodymount bolts onmy 92 yj
Dont get into it unless you have a lot of time to kill. I had to cut mine out. Are your caged nuts ok?
the nuts are ok and i bought a daystar 1" body lift i dont know how i should lift the body to get to the mounts
I did one side at a time. I put a piece of plywood under the length of the rocker and used a 4x4 to push up on it with a jack. If all your caged nuts are good you are lucky. Make sure every bolt is able to come out before you start and uze antisieze in case you ever want to take it out.
