Bought 52 inch Eyourlife which wire harness is needed? Also will the rough county 50 inch brackets work. I see some say yes some say no
I will be adding the day star panel.
Also
Bought 52 inch Eyourlife which wire harness is needed? Also will the rough county 50 inch brackets work. I see some say yes some say no I will be adding the day star panel. Also
I wouldn't use a 50" bracket on a 52" bar. They tighten weird and my buddy had his partially fly off on the highway doing that. Pretty sure Eyourlife makes 52" brackets cheap.
Jeeper
Those mounts will work fine, they do have a gap between the mount and the windshield frame (about 1/2" at the top (because of the bar width) but it works fine. As far as the wiring, I wired it to a relay mounted under the hood (screwed to the firewall on the right side) and powered it though a push-button switch on the A-pillar, powered from the accessory/lighter circuit.
Thanks i was looking for what brand to get but i bought the
http://www.amazon.com/gp/product/B00R7IOOMS?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Thanks.
Jeeper
That will work fine - you will just need to determine where you want to pull the 12 Vdc input for the switch to light & power the relay for the light. I used the "12 V power adapter" from Quadratec - provides an ignition switched 12 Vdc source under the dash for easy power application to the switch;
Quadratec Exclusive JK-APT2011 - 12 Volt Power Adapter for 99-16 Jeep® Wrangler TJ, JK , TJ Unlimited & Wrangler Unlimited JK - Quadratec
