Can someone please explain to me what the bracket is for that some people weld on their C shaft where the axle U joint is? Shhhh.. I'm a noob..
It's to reinforce the "C's" - forged part that the ball joints mount into.Can someone please explain to me what the bracket is for that some people weld on their C shaft where the axle U joint is? Shhhh.. I'm a noob..
Do the C's bust that easy? or is that just hard core off roading?It's to reinforce the "C's" - forged part that the ball joints mount into.
It's not so much the C itself as it is the axle tube where the inners are welded on. They tend to bend there under heavy impact/stress. Daily driving it won't, although if running really large tires it could possibly happen on some rough roads or a big pot hole (pure speculation happening here).Do the C's bust that easy? or is that just hard core off roading?
$30 to $40 for the RK gussets. Only uppers, which is really just where you need them.It's cheap insurance. That said, I have not done it....yet. A lot of "kits" include inner axle tubes and LCA skids as well. For about $200 and welding cost, a decent way to beef up your axles.
Don't the lowers help reinforce the uppers? i.e. While one resists pushing forces, the other resists pulling forces?Only uppers, which is really just where you need them.
Nah. The majority of the extra stress is in an upward direction. Pushing up, generally speaking, doesn't apply downward force on the lower C.Don't the lowers help reinforce the uppers? i.e. While one resists pushing forces, the other resists pulling forces?
Wouldn't those be a balance issue? Isnt it like an L bracket welded half on the C and the other part of the L welded on the axle shaft right before the C? Or are these welded on the axle tube?Nah. The majority of the extra stress is in an upward direction. Pushing up, generally speaking, doesn't apply downward force on the lower C.
Some folks prefer the C gussets that go on upper and lower. They're still not very expensive, so put on whatever makes you feel most secure. :thumb:
They weld onto the C forging and axle tube, not shaft. No contact to moving parts whatsoever.Wouldn't those be a balance issue? Isnt it like an L bracket welded half on the C and the other part of the L welded on the axle shaft right before the C? Or are these welded on the axle tube?
AHHH... Got ya .... Thanks for thatThey weld onto the C forging and axle tube, not shaft. No contact to moving parts whatsoever.
:thumb:AHHH... Got ya .... Thanks for that
