Brake fluid level is low due to a nick in the fluid container. I have no idea how this happened :confused: Took her out for a day on the trail and then I saw a small puncture towards the top of the brake fluid container. So I took a heat gun and kind of melted the plastic together to fill the puncture.(talk about custom...) Regardless... Does anyone know what brake fluid I should use to fill the level back to where it needs to be? Any input or opinions would be appreciated
Should say on the yellow cap. Should be dot 3/ dot 4.
Just put dot 4 in it, you'll be good.
As mentioned, it's on the cap. It's also in the owners manual. And, lastly, Amsoil is a great resource for pretty much any fluid that goes in your car from transmission, to brakes, to engine, to differential, etc.
