Was told by stealership that my brake fluid needed to be flushed. It failed the chem test.
Is bleeding the brakes (all four corners and ensuring that the master cylinder doesn't run dry..keeping topped off with new fluid) the same as whatever the dealership or for example a firestone/pepboys might do for a "brake flush"
I need to replace my rear wheel cylinders soon and will need to bleed brakes, but since I was told the fluid is bad anyway I want to make sure I do everything right.
Thanks.
