97 TJ sport no ABS
pass caliper was seized/stuck replaced with NAPA reman
bled system per Haynes manual filling with new fluid during the process
pedal has good resistance with jeep off
pedal goes to floor with very little force when running and brake warning light on
bled system again....a lot.
same issue.
there doesn't appear to be any leak in system
one weird thing I noticed the first time is the driver parking lamp went on while pressing brake pedal. after I turned jeep on and off this has not happened again.
Manual says with this problem there is little or no fluid. but its at the full line.
Any help would be appriciated
Knows a couple things...
Your left and right calipers are swapped placing the bleed valve at the bottom instead of the top where it needs to be.
Problem solved! It makes it a hell of a lot easier to bleed when the bleeder is on top. I should now read my own signature. Thanks jerry i have done calipers a few times before but never made this mistake. Oh well.
