Not sure what the 7 3/4 LED's are but any LED bulb that you install will need to have a resistor installed in line or they may be built in to some, if it doesn't have the resistor then it will draw a lot less power than the module is expecting and trigger a light out, like your signal lights that flash fast if you have a bulb out.
