Hey yall,
I got a 98 TJ that all of a sudden the brake lights do not work. Specifically, the brake light above the spare tire works perfectly fine but the two lower brake lights do not work. The directionals and the nighttime running lights work fine but when I hit the brakes the lights do not brighten up if the running lights are on and they don't light up at all if the running lights are off. I replaced the bulbs even though they looked fine thinking that hopefully that would solve it. But no such luck. The new bulbs didn't change anything. So my question is what the hell should I do/check to try to fix my brake lights so that I can continue driving my baby? Also Has anyone else had this problem and what did you do?
PLEASE help me figure this headache out
Thank you:atomic:
Thank you:atomic:
