My TJ has a left brake light problem I can't figure out.
With lights off, brake lights work fine.
With lights on and brake pedal NOT depressed, all lights work fine.
With lights on and brake pedal IS depressed, left rear tail light goes off and brake light doesn't come on.
Have changed bulbs twice, no go.
Where would you start looking?
That sounds like a short / bad ground ..
My boat trailer use to do same thing when pushing brake down all the lights went out brake up everything was fine . I had a bad ground on trailer .
take your tail light out look for a bare wire ..
Not sure if jeep is the same but check you got the bulb in right had a nova if the bulb was in wrong it would not work right
