Just need a quick answer.​
Hooking up an axillary braking system to tow the Wrangler 4-down.​
Need to tap into the brake lights at the switch.​
Which wire (color) coming out of the switch activates the brake lights?​
Thanks!​
Administrator, please delete post.
Thanks
Did you find the correct wire color? Which auxillary brake system are you using?
Went with white. Everything listed white as brake light color.
Installed a US General Unified Brake System. Picked it up used, with a Sterling tow bar for $45.00. I think the brake system sells for around $1400 new. Installed and towed 600 miles. Works great.
