Hey folks,
Starting to work on issues on my new (used) TJ, first up is some issues with the tail lights. Left side works fine, top brake light and right brake light/turn signal doesn't work, though the light itself does. I suspect them to be related.
Was working on the top light and followed some tips I found on here to check the connection up above the plastic wheel well, but after making sure it was secure still no go and checking the connecting point in the tub with a multimeter I got no power. I scrubbed them off with a wire brush as well.
I suspect they're related because I noticed that it looks like the wiring for the top light and the back right connect at the back right of the vehicle and head toward the center. Does anyone have a description of where the next point I might check from there is? Or any other troubleshooting tips beyond what I found and tried on here?
Thanks!
Thanks!
