A LJ and TJ lacks BLD but JK has them
Look at this video
https://www.youtube.com/watch?v=9-JunXFXDq0&list=UUJe_ZHBRKBvs8bAT31GtA9g
Look at this video
Any idea if that was unlocked?A LJ and TJ lacks BLD but JK has them Look at this video https://www.youtube.com/watch?v=9-JunXFXDq0&list=UUJe_ZHBRKBvs8bAT31GtA9g
The JK did not have lockers, only BLDAny idea if that was unlocked?
Cant get link to work.Rubicon have lockers and BLD
Sahara have no lockers but BLD.
Please read the description under the movie.
Here it is
"Jeep Wrangler JK's going through a grade 5 obstacle at Moegatle.
Jeeps & mods (to best of my knowledge) in order of appearance:
Cant get video to work
JK Unlimited Rubicon Auto - stock
JK Unlimited Rubicon Auto - 3" Zone Lift w/ BFG MT 285/70
JK Unlimited Sahara CRD Manual - 3" Old Man Emu HD Lift w/ BFG AT 285/70
JK Sahara Auto - 3" Old Man Emu HD Lift w/ BFG AT 285/70
JK Unlimited Sahara Hemi 6.4L Auto - 4" Lift w/ BFG MT 35/12.50, Air Lockers
Apologies for clip ending abruptly. Used a trial version dvd ripper and could only get 5 mins of footage from the dvd.
I must add the last JK did make it through after locking both Air Lockers.
The 2nd last JK eventually went around after sustaining damages to the front axle."
There are offcourse different drivers with different skills, but in this movie the Rubicon made it and Sahara did not exept the last sahara that did have airlockers.
https://www.youtube.com/watch?v=RO4DXXYBoGY
BLD cannot be turned off, it remains on in 4H and 4L even if you turn off traction control.BLD only works in 4wd? Also when you are in 4wd lo or hi if you turn off traction control does that turn off BLD?
This demonstrates that the BLD is not a substitute for true lockers. The BLD must expend twice the torque to negotiate the obstacle because it needs to overcome the brake and the obstacle. In most cases the jeep will have enough torque unless you're gearing is too high (numerically low).Rubicon have lockers and BLD Sahara have no lockers but BLD. Please read the description under the movie. Here it is "Jeep Wrangler JK's going through a grade 5 obstacle at Moegatle. Jeeps & mods (to best of my knowledge) in order of appearance: JK Unlimited Rubicon Auto - stock JK Unlimited Rubicon Auto - 3" Zone Lift w/ BFG MT 285/70 JK Unlimited Sahara CRD Manual - 3" Old Man Emu HD Lift w/ BFG AT 285/70 JK Sahara Auto - 3" Old Man Emu HD Lift w/ BFG AT 285/70 JK Unlimited Sahara Hemi 6.4L Auto - 4" Lift w/ BFG MT 35/12.50, Air Lockers Apologies for clip ending abruptly. Used a trial version dvd ripper and could only get 5 mins of footage from the dvd. I must add the last JK did make it through after locking both Air Lockers. The 2nd last JK eventually went around after sustaining damages to the front axle." There are offcourse different drivers with different skills, but in this movie the Rubicon made it and Sahara did not exept the last sahara that did have airlockers. https://www.youtube.com/watch?v=RO4DXXYBoGY
I was personally trying to better understand the BLD system. So I began to research.Chrysler Blog - Jeep Brake Traction Control Explained Directly from a Chrysler engineer.
From my research I found that the LSD compliments the BLD.So what about the Limited Slip, How does that work into the equation. I know the Rubicons with lockers don't have it but do all the other Jeeps have it.
LSD will help, but it is an option for the rear axle on Sahara's only. A front selectable locker with rear LSD is an excellent set-up for those that want to DD their vehicle and conquer something less than a grade 5 obstacle (or so I'm told).So what about the Limited Slip, How does that work into the equation. I know the Rubicons with lockers don't have it but do all the other Jeeps have it.
Actually it's an option on the Sport S too... Because I have it on my Sport S.LSD will help, but it is an option for the rear axle on Sahara's only. A front selectable locker with rear LSD is an excellent set-up for those that want to DD their vehicle and conquer something less than a grade 5 obstacle (or so I'm told). I think the 4:1 TCase was also exceptionally helpful for that obstacle.
Thanks, Odamo. You described it really well.There is one phenomenon that we are not accounting for here: Torque cannot exist without resistance. If an engine can produce 240 lbs/ft it does not mean that it always is. If you were to place the whole jeep on blocks and place it in drive you will only have the amount of torque necessary to rotate the mass(drivetrain, tires) . Thats why on a Dyno there are rollers that apply "resistance" and then you can measure the amount of resistance that can be overcome(Torque). Don't confuse rotational speed as being the same thing. On an open diff,lets say one wheel on glare ice, the other on dry pavement- both wheels will see the same amount of torque. If it only requires 15 lbs/ft to spin the tire on ice, the tire that is not spinning is also receiving 15 lbs/ft, even though it may look like its doing nothing it is applying effort to the ground. Although it is likely no wheres near enough to move the vehicle. When you apply some amount of additional resistance to the spinning tire(LSD, BLD) the non spinning tire will receive a commensurate amount of torque and hopefully be enough to move the vehicle. If its an LSD it may still not be enough. The BLD can completely stop the spinning tire if needed and send enough torque to propel the vehicle GreenMachine13s explanation is accurate in stating how the torque "NEED" plays out. I guess you can tell we are all loving our Jeeps. :awesome:
