So I took my 2007 JK out today for some off roading. Hit some huge bumbs along the way but I figured she could handle it. However, when I got back on the road I noticed that my brakes were not quite right. I was hitting the brakes but I was barely braking. I can slow her down, but I can't come to a full stop anymore without using my E brake (Jeep is also a manual).
I checked the brake fluid level and its inbetween min and max. I also checked the brake pads and they seem to be fine. Any suggestions?
UPDATE: Went out to drive it around the block and see if I could build up pressure by pumping the brakes a few times and now my brake light is on. And my brakes are still not responding like they used to.
Hit some huge bumbs along the way but I figured she could handle it. /QUOTE]
If your talking about huge bumps at speed, Jeeps aren't really great at that. Maybe you dislodged something, you'll have to jack it up, pull the wheels and inspect/trouble shoot.
If it's that bad, there should be some physical/mechanical evidence
disconnected a brake line maybe???
