1 - 15 of 15 Posts
Plan on ordering Teraflex 2.5 suspension lift. Does this require break line extension? And if so does this kit come with it?
After you install any lift you should always jack it up by the frame and droop the suspension fully and see what happens, of course.
The kit does come with extension brackets for the rear. Front doesn't require it.
Depending on your year/model you may need exhaust extensions that are sold separately.
What year do you have? I noticed the brake lines are quite a bit longer on my 2013 than the 2011 I had.
I just installed a rancho 3 inch lift yesterday on 2013 jku replaced lines because it came with kit but I think other poster is correct 2013 lines would of been long enough.
on 2011 and up they started to mount the brake lines to the bottom of the spring pad on the front. You just need to take this bracket off. Our 2.5 kit will come with drop brackets for the rear.
Definitely disconnect the bracket. On my 2012 CoD MW3, the steel 90' elbow is not quite 90' any more at full droop of the suspension. So this tells me I would be in trouble when I disconnect the swaybar for the extra 25% travel. Should be no issue with the bracket disconnected, but I have yet to try it.
(Only had the JKUR CoD for 3 weeks - that's why I haven't used the swaybar disconnect yet) :whistling:
What's your recommendation in terms of securing the bracket once its removed?
I just installed the 2.5 coil lift this weekend with bilstein 5100's. Make sure you take the brackets off from the original mounting location. I put a little header wrap on mine along with some black-duct tape to keep them from clanking around until I decide if Im going to dremel off the bracket or make me a new mount. I have a 2011 and the lines are nice and long, but the brackets restrict the movement of the lines after the lift & shocks...Big Time!
Typically we run them between the shock and spring and then loosely zip tie them to the shock so they stay secure but can still move with the suspension.
1 - 15 of 15 Posts
