I was putting nerf bars on my brothers 2014 JKU and he got the wrong bolts from the hardware store and it broke off one of the nuts up in the body mount. I have the bolt out and I am not sure if the nut is part of the rubber mount that I can replace or if it is part of the body or frame. I'm thinking I could drill a pilot hole up through and use a small hole saw to get to the nut. I would like to avoid that if I can replace the mount.:facepalm:
You'll have to cut a flap in the tub to access the nut. You may need to weld a new one in. This is a common issue when replacing body bushings.
