i have a 99 TJ SE. when i bought it it had a shitty aftermarket radio so i bought a stock one for cheap. the radio doesnt seem to work though, it only displays the time for a couple minutes on and off. none of the buttons do anything but there is definetly power going to the radio. most of the time the thing is completly dead except for the couple minutes that it likes to display the time. is there some secret jeep radio quirk i don't know about?
Both stock and aftermarket non can bus (wrangler went to can bus in 2007) radios have to have both battery power and accessory key on power so they know to shut down when key is in off position
Post a picture of the radio you have
A lot of good info on stock keep/dodge Chrysler head units here
One interesting comment from this link
“ You could even get the time with the ignition off by pressing the volume knob, a welcome feature that continues on many Chrysler decks to this day. “
So my guess is that is how you got time to display without an on/accessory power source hocked up
4502670
this is the radio model i have
That deck is built by alpine has three band equalizer and was used in the cloud series cars of the late 90s
Sounds like you have plus 12 to battery wire but not yet properly connected to plus 12 from accessory key wire
Pin7 on the gray connector goes to battery always plus 12 and pin 6 on the same gray connector must get plus12 when key is in accessory or on position or radio will not function
Pin 1 on same gray connector is not used
