OK, this install of the 2" BB and shocks is gonna break me in right. Got the front all installed just fine.....unbolted the sway bar, dropped the axle as far as possible.....and pushed the axle down while using a pry bar, popped the springs back into place. No sweat.....
Got to the back, and 3 out of 4 bolts for the upper end of the shock snapped as we were trying to remove the stock shocks. On the driver side, we were able to drill out the snapped bolt...need to re-tap it I guess.
On the passenger side, both bolts snapped. And they won't drill back out, even using brand new sharp bits. The one right next to the frame rail doens't even leave room to get a drill straight on it.
So the best plan we can come up with now is to just leave the bolts since they're broke off recessed below the plate. And weld in some studs, and mount the upper part of the shock to the welded studs and drive on a nut.
So watcha think? SHould this work? Any other ideas? I imagine this is pretty common on these things....seems like shock bolts snap pretty easy....and the location of those rear ones are terrible!
