buddy of mine had this happen in his cherokee..same shock actually,,,he just had it welded in lol not sure what else to do unless you fab up a mount and weld that mount to there and then bolt the shock to it
Mine is a little different. I wish mine was that easy to fix.weird! my friend's YJ just did the same few hours ago! i think simple welding should do the trick
I agree on that one for TLATEOTW's friend.Is your Jeep lifted? If so, make sure you have enough bumpstop. Your shock bottoming out may have caused this.
