My t-case shifter broke or something come lose the other day the first time I put it in 4x4 lo after installing a 2" lift with 1" shackles and t-case drop. It went into 4hi fine but broke when I pulled it into 4lo. I had to crawl under the jeep to put it back in 2-wheel drive but couldn't tell what was broke at that time and I've been working 13 plus hours on nights and haven't checked it again.
Stupid phone. It moves up and down like its not hooked up to anything. Any thoughts as to what happened. It's a 89 with 4.2 and auto trany.
sounds like the linkage rod might have come undone from were the shift lever hooks to the T case. if that is still hooked up then look at the rod. there is a bolt that tightens the slippage down. ensure this is tightened that way the linkage is not just sliding back and forth on the linkage rod
