Hi" I'm new at this and could really use somme info.
my 89 yj 2.5 5speed won't run right now that it's gotten cold out. when its in the garage all nite it will run fine but let it sit out in the cold for hrs. it will start right up but will not idle, you must keep pumping the gas pretty fast to keep going when u go to shift a push clutch in it will stall. once engine gets warmed up it will run fine. I replaced the air temp sensor, checked the distributor cap for moisture, plugs a wires are new,sprayed carb cleaner, injector is sprayinf fuel at idle and while accelerating.
could the choke be the problem it just seems like it thinks it warm out when its not.
thanks for any help riverrat
