Another victim of frame rust....
All prices are OBO.
I really just need it all gone to make room for the next project.
Everything available to pick up.
I will ship ups at your expense.
For parts not listed just ask, it all needs to go.
I will take names and hold parts, won't be taking it off the road till week of 7/10.
(winch not for sale)
4.0L engine - $450
- only 139K miles, runs super strong, zero issues
AX-15 Trans - $300
- only 139K miles, shifts well, zero issues
231 t-case with SYE - $300
- TERAFLEX EXTREME SHORT SYE installed
Rear Driveshaft - $100
- ADAMS extreme duty CV driveshaft for YJ lifted 4-5”
Front Driveshaft - $100
- ADAMS extreme duty front driveshaft for yj lifted 4-5”
Front Dana 30 - $700
- NEW 4.56 MOTIVE gears and master overhaul kit
- SPARTAN Locker
- single piece XJ shafts with new, larger 5-760X u-joints (dana 44 size joints)
- less than 10k miles since rebuild and gears
- have new u-bolt style yoke with seals/bearings for it- new in box
Rear Ford 8.8 - $1300
- ECGS prepped axle with new 4.56 MOTIVE gears
- Rebuilt Trac-Loc differential
- Disc brakes
- new hard brake lines
- excellent condition
- stronger than dana 44
One ton steering - $200
- Rugged Ridge one ton yj upgrade
- Huge TRE’s and much stouter links
- Tie Rod and Drag Link with new procomp stabilizer
- direct bolt in replacement
(both axles and one ton steering together goes for $2k)
MORE steering box brace, never installed - $40
TJ extended flares (not mounted on jeep in pics) - $100
Hard top - $300
- excellent condition, black with white interior, all glass intact
Family Roll Bar - $200
- Turquoise blue, zero rust, perfect condition with grey padding
Full Hard Doors - $400
- Good shape, windows and locks work, factory drivers side mirror broke off, have replacement
Tailgate - $150
- small rust patch on bottom, see pics. Lock functions well
Hood - $150
- Great shape, small scratches and bumps
Hood hinges - $50
- perfect condition, all hardware
Hood catches - $40
- black, great shape
Grill - $125
- Great condition
Radiator - $150
- BRAND NEW DENSO UNIT less than 2 mo old
Steering box - $50
- no leaks
Steering column - $50
- everything works
New Exhaust System - $175
- New improved header with flex pipes
- TJ style mid pipe for better ground clearance
- Magnaflow Hi-flow Catalytic Converter
- Dynomax Super Turbo Muffler
- Sounds killer on the 4.0 motor
3.5” lift springs - $150
- Rough Country
- Military wrap heavy duty springs
- 2 extra rear spring packs
- 6 springs total, two unused - never installed
1” lift Boomerang Shackles - $80
- super heavy duty shackles
Bilstein 5100 shocks - $160
- for YJ with 4-5” of lift
4- Wheels - $100
- 15X8 black steelies in great shape
- 3.75” backspacing
4- 33” tires - $400
- Dick Cepek Mud Country
- Lots of tread left
- great on-road and excellent off-road
DIY sliders - $50
- 2 pcs of 5" x 4" x 3/8" steel angle cut to length for sliders. Haven't gotten around to drilling them yet. They just need holes drilled and they're ready to mount. 2X thicker steel than store bought sliders. Primed, ready to paint.
- the gas tank crossmember and the rear crossmember are new pieces, Once everthing is sold off those will be available if you need them for repairs on your rig. see pics.
Doors
Doors still available? Willing to ship on my dime? How much rust, if any?
