1 - 19 of 19 Posts
when i hit a moderate bump on the right side of my jeep, i hear a clunk sound... its just been happening recently, i havent been offroading in a while (a tragedy really...) so i dunno why now im hearing it. :confused:
Retired Moderator
Yeah, and check over the bushings too. You could just be due for changing out some of them.
From an 01 FSM, might point you in the right direction?
DIAGNOSIS AND TESTING - SUSPENSION AND STEERING SYSTEM
CONDITION POSSIBLE CAUSES CORRECTION
FRONT END NOISE
1. Loose or worn wheel bearings. 1. Adjust or replace wheel bearings.
2. Loose or worn steering or suspension components. 2. Tighten or replace components as necessary.
EXCESSIVE PLAY IN
STEERING
3. Loose or worn steering gear. 3. Adjust or replace steering gear.
FRONT WHEELS SHIMMY
3. Tires worn or out of balance. 3. Replace or balance tires.
4. Alignment. 4. Align vehicle to specifications.
5. Leaking steering dampener. 5. Replace steering dampener.
VEHICLE INSTABILITY
3. Tire pressure. 3. Adjust tire pressure.
EXCESSIVE STEERING
EFFORT
1. Loose or worn steering gear. 1. Adjust or replace steering gear.
2. Power steering fluid low. 2. Add fluid and repair leak.
3. Column coupler binding. 3. Replace coupler.
4. Tire pressure. 4. Adjust tire pressure.
5. Alignment. 5. Align vehicle to specifications.
VEHICLE PULLS TO ONE
SIDE DURING BRAKING
1. Uneven tire pressure. 1. Adjust tire pressure.
2. Worn brake components. 2. Repair brakes as necessary.
3. Air in brake line. 3. Repair as necessary.
VEHICLE LEADS OR
DRIFTS FROM STRAIGHT
AHEAD DIRECTION ON
UNCROWNED ROAD
1. Radial tire lead. 1. Cross front tires.
2. Brakes dragging. 2. Repair brake as necessary.
3. Weak or broken spring. 3. Replace spring.
4. Uneven tire pressure. 4. Adjust tire pressure.
5. Wheel Alignment. 5. Align vehicle.
6. Loose or worn steering or suspension components. 6. Repair as necessary.
7. Cross caster out of spec. 7. Align vehicle.
KNOCKING, RATTLING
OR SQUEAKING
1. Worn shock bushings. 1. Replace shock.
2. Loose, worn or bent steering/suspension components. 2. Inspect, tighten or replace components as necessary.
3. Shock valve. 3. Replace shock.
IMPROPER TRACKING
1. Loose, worn or bent track bar. 1. Inspect, tighten or replace component as necessary.
well, today i noticed it when i quick turned the wheel back and forth at a standstill, but the sound is coming from the front right... i also noticed when i was parked i had my wheel cut, and there were parts underneath rubbing the tire and the rim...
im rather confused
If you have anyone that can help you, jack up the front of the Jeep, and put jack stands under your front axle, high enough to get your wheels off the ground. Now have the other person slowly turn your steering wheel, lock to lock, while you observe the front end through the rotation. Something is bound to be loose, from your description. If that does not show anything, try crabbing the right front tire, in the 12 - 6 o'clock position, and see if you can wiggle it. If there is any play in the tire, your wheel bearing is shot. Once you have done all this.........let us know your results. Or, if you are not willing to do this, please take this to your favorite mechanic, and have him/her check it out.
check your trac bar first. get your front suspension articulated both ways and see if the ball joint in either of your sway bar links is seperated on either side. mine was seperated and i fixed it last week. i did however self diagnose prematurely and put a new upper and lower ball joint in first ($95). when this did not fix the problem i did what i said above and it was obvious what the problem was. i ended up paying $150 for a fix that would have only cost $50 if i had just slowed down and checked things out.
check track bar
I put a 4 inch. lift on my 01 sprt and it does the same thing sometimes. After looking at it I found it was a loose bolt where the track bar connects. every once in a while it does it again and I just tighten it back up. I should probably buy some lock-tite for it put keep putting it off.:rolleyes:
01 TJ sport, 4 inch lift,d30 front and d44 rear, rear true track diff, nerf bars., k&n, power aid throttle body spacer.
Retired Moderator
bmanrkg3 said:
which one is the trac bar? pic with outline plz
It's the one that runs from the frame by your steering box to the axle on the passenger side, at approximately the same angle as your drag link.
nice info BLUESMAN, looks like someone else here has Alldata pro.
most common clunks can be traced to worn sway bar bushings, check for dry rotted bushings when jeep is on jack stands. these are very hard to tell when vehicle has full weight on tires.
1 - 19 of 19 Posts
