I've dug around and watched all the videos I can find on this subject, but I have question for someone that's done and used this mod.
What do you do about venting the bumper?
I was planning on using this garboard drain plug for the fill as well as the pick up line:
Robot Check
If it's air tight, at best the pump will cease to draw after it pulls out a little water, at worse I'm afraid I'll collapse the plastic bumper at some spot.
Have you that have actually done this mod drilled a little vent hole at the top?
Robot Check
