Commercial Member
I want to get a new bumper and a winch. Just had a silly question. Do the winches all have same mounting points for any bumper? Are the winches bumper specific? Here's the bumper I was thinking of getting. 07 16 Jeep Wrangler JK Front Bumper w OE Fog Light Housing Black Textured | eBay And here's the winch I was thinking Superwinch - LP8500 Winch | 4WheelParts.com Nothing fancy. Just wanted to know if the two would work together. Thank you!!
The standardized bolt pattern is 10x4.5. The differences in configuration are mostly how much they're offset (how much they hang off to one side more than the other, from the mounting point). Some go over 6", usually on the passenger side, some are pretty much centered.
The one you're looking at getting doesn't have a recessed winch mount. You should be good to go :thumb:
EDIT:
You may need a vacuum pump relocation bracket, for recessed winch mounts. They're inexpensive...if you have a 2012+.
