By passing AC unit
1336 7
Just curious if there were TJ Sports without AC
and if so do they just have a shorter belt?
I believe my ac clutch is shut cause of this constant grinding/whistle noise i am getting out of that side and was just thinking about by-passing it with the belt and seeing if that is the real problem instead of buying all new parts
is this plausible?
I dont need the AC right now
and I am just thinking that this would be a cheap easy way to find out if the noise is actually coming from the ac clutch/bearing or what not
so all i need to do is go get a belt for a 97 TJ Sport 4.0 with out air?
thanks everyone for the help
well i dont have the lil diagram in front of the radiator anymore...
but I am sure I can figure it out :}
and JeepCrawler you are a sneaky bastard
:D
well in case anyone else was getting the same noise
that is like a constant metal rubbing noise
1st check the idler pulley.. take it off and clean out the mud
I 1st did the by passing of the ac unit
then still had noise so next step was the idler pulley
15.44 and changed it and no noise :}
well I still have AC but i dont have a belt around it
mainly because I am getting a new motor installed in a month and dont need to fix the AC leak (gasket) and fill it up and then turn around and do it again if it gets the seal cracked again
but thanks everyone for the help
p.s.
Bluvikng
how did u get that sweet avatar?
