Couple updates, but I have not been idle. Picked up a fresh pile of parts Saturday. Still waiting for the axle brackets from Currie but I did grind clean the rear diff and prepped it for the new brackets.
Steering arms for the Dana 60
Diff cover for the 60
Yukon hardcore hubs
5.38 OEM Dana gears for the front
Open 14 bolt diff case so I can install a Detroit in the back
TMR 15 bolt high clearance rear diff kit came for the 14 bolt
Teraflex sway bars front and rear
6 inch coils from Teraflex - my snow wheeling coil height so I can get 44s under this rig.
First up was some work on the 14 bolt. The 15 bolt kit shaves off close to 2 inches off a 14 bolt style diff. I have a more modern 2004 10.5 version and the kit says for pre 87 14 bolts but it all worked out fine. At this point the bottom plate is just tacked in. I was getting low on welding gas so will heat the cast and weld it up tomorrow.
Started cutting into the dash now that my steering parts are all in. I got the security disconnect, install kit and a basic three spoke steering wheel from Grant to match up with the Ididit steering column. I also worked on getting the Dakota digital gauge cluster into the dash.
Last but not least I cut off the rear track bar like I did in the front and made a new one out of 1/4 inch plate.
Parts!
diff covers
TMR 15 bolt high clearance kit for the 14 bolt
Dash cutting
Steering column
Grant lockable steering wheel disconnect system. Splurged for 15 bucks and got a Jeep horn button
