1 - 10 of 10 Posts
^^ if I understand it right, the only reason is because you run the older door surrounds which don't work with it. But if you run after market door surrounds you should be fine!
I just installed mine today and already love it! Way better then the soft top also!
door surrounds
Gotcha , thanks - hmmmm - so the newer surrounds won't work with my 08 soft top! If I picked up a wrap around windjammer I could probably run the winter without the top on...
1 - 10 of 10 Posts
