Strange thing, Monday morning woke up to a dead battery, since I was trying to go to work, I got jumped and when to mu local Sears for a Diehard battery. No time to find an Optima or something else. Its a nice big powerful Diehard and always had lick. Usually get 3 yrs plus in the SFLA heat co aired to 1.5-2.5 with other stock batteries.
Well, since the battery change, MPG is up from 12.1 to 16.9 MPG. Is that possible? Same driving conditions, etc.
Perhaps unplugging the battery and resetting the computer did something when the system relearned your driving habits.
Actual or displayed ? Before I had injectors replaced on my 2500 Cummins, the display would be 20. After the injectors 17, but the actual mileage never changed, same 19 average.
I can't believe a low battery would impact mileage, unless maybe the AC was causing more drag - but I think RoadiJeff may be correct if it is actual.
There's a regulator that gives the PCM what it needs in terms of voltage and current. As long as the battery is working, you won't see a change. (sure - rebooting the system might restore normal programming)
Its via the computer. Will see actual on next fill-up. But the computer has always been with .2-.8 with actual.
