1 - 12 of 12 Posts
Don't know. We want to switch to the black wheels that come with the Call of Duty or something similiar. Not being built for off road. My wife drives it on the highway to work 50 miles every day.
You should have no problem. I had a 2010 Sahara, with the 18" wheels. Now I have the new Arctic, which is basically the Sahara edition, with Rubicon suspension, and CoD/Rubicon wheels & tires. My wheels are black, I think the CoD are dark grey,,, but basically the same wheels. My Arctic/Sahara runs great on 17" wheels with 32" LT255/75 R17 tires. You should be able to switch, no problem.
The Rubicon tires on the Arctic do not seem to roll as easy as the Bridgestones on the Sahara. That probably lowers the gas mileage. If I remember, my Sahara tires were also 32" on the 18" rims, so my guess is that the affect on the speedometer should be negligible, if there is any affect at all.
Thanks, thats exactly what we want. Does it affect the gas mileage or speedomotor?
If you are going from the factory size 255/70/18 on 18" wheel to the factory size of 255/75/17 on 17" wheel then your speedometer should really not be effected. according to the tire calculator on discount tire website the difference in circumference is .02 and says that at 65mph you would be going 65.01mph with the 17" wheels.
I believe they chose these sizes for factory so they could just calibrate one speedo gear and not matter which tires/wheels they put on at the factory.
I'm going through this same calculation for my 2012 Sahara JKU. After investigating different tire sizes and wheel choices ad nauseum, I think I'm going back to reversing the OEM OWL Bridgestone Duelers black-side-out, powder-coating the factory wheels for $140 a pop -- then forgetting about it until the tires wear out! My head hurts.
I had my 18" powder coated for $86 each. Came out great!
A change in wheels will NOT hurt your gas millage or speedometer. However a change in tire size can effect those things. Most people typically ditch the 18's as soon as it is reasonable to do so as the cost of tires of a 18in rim is stupid high compaired to the same tires for a 17 inch or smaller rim no. It also applies to airring down purposes but since your jeep is DD only that really doesn't apply to you
1 - 12 of 12 Posts
