Does anyone know if the Superchips Flashpaq has this function? Looking to jump off headlight to run running lights and dam flicker is a pain.
From what I understand you need to put a resistor in line with the headlights to stop flicker. Each manufacturer offers a pig tail resistor for their lights.
Grumpy Old Guy
This. Read the thread at the top of the page about the CANBUS system.
Using Appcar, I was able to stop the flickering by changing the bulb type to HID(?). If Flashpaq allows you to do this or similar, it may work.
Reactions: jdinny
Supposedly the JScan app can tell the Jeep to change the PWM voltage to constant for LED lights but I am not sure if it covers all years. I am using the Susquehanna box on her 15 JKUR. The first relay I had in my 09 was one that I took off my TJ when I sold it. It worked fine for a few years and then the contacts started sticking. Had to tap it with a wrench to get the headlights to turn off. I replaced it with another cheap ebay relay and the trigger voltage of the new one was higher and I had to add a Truck-lite anti flicker harness to get the relay to turn the headlights on.
