Can someone get their tape measure, and measure the space between their lower shock mounts? Or, if you have an unmounted Wrangler shock, measure how wide the end of it is? See pic.
I'm doing a ground-up build, and I put in different axles. It's too early in the build to buy shocks, but I need to weld the shock brackets to the axles and rear frame before I paint them. So, I'm going to make an adjustable shock fixture to help me align the top and bottom shock brackets.
I've have a old set shocks here and the size is 38mm ,that's the size of the tube that sits inside the bushing
hope that helps
hope that helps
Thanks. Perhaps my drawing wasn't clear enough, but I need the total dimension that goes to the outsides of the bushings.
Cool, thanks for your help!!
