Ok I have a 97 TJ 5 speed 4 cylinder the tranny mount is broke in half is it possible to do this job with out dropping the pan thing the goes across the frame rails
Yes no problem. Take the 4 nuts off the skid, jack up the engine/trans where they join using a block of wood on the jack. Look thru the 4 openings on the skid and you will see the 4 bolts to remove the transition plate. take them out and slide the plate off the exhaust bracket. Your done.
Ok just asking cause my frame is rusty and I don't think the bolts will come out with out braking the welds inside the frame
