So, I stop at a red light, stop sign, etc. When I take my foot off the brake, the ABS and Traction control light comes on sometimes. As I start to depress the accelerator, the right front wheel brakes. Or at least that's what it feels like. I've changed the right front ABS sensor, problem stills exists afterwards. The lights will go off for a while and then come back on. Whether the lights are on or not, there are no OBD codes.
Has anyone experienced this? Does anyone understand it and how to fix it.
It's a 2012 Wrangler and it only has31k miles on it. Completely stock too.
Thanks...
Don't have any experience with the issue your having, wonder if maybe you got a unit bearing going bad
May sound silly, but check your battery terminal connections. A loose connection has been known to cause weird things like the ABS and traction control lights to come on and off.
Check tie rod and drag link ends. I had a drag link with bushings worn at both ends that caused this. Replaced drag link and all is good.
