my Cb stopped working and i took this apart and i know this is the problem. Is this repairable? or do i just replace the hole cable.
Mike
Depending your electrical skills, yes and no. Solder on connectors are available. However the questions you should ask yourself are as follows.
1: Is that quality coax cable or cheaper grade coax?
2: If it is good coax how good are your soldering skills?
If it is low quality cable replace it (preferably with good cable. If its good cable and you aren't uncomfortable soldering a new connector on you can take it to a radio shop and have it done.
