Hi all - I have the Terraflex HD tire carrier, tire mount, and the brake light extension kit which has a CB mount integrated.
However I find that the CB mount location doesn't work, there's not enough clearance between the tire and the bracket for me to screw in the antenna or a spring.
Has anybody faced this and come up with a good solution?
I could never get the built in one to work. My solution was a mount from Quadratec that bolts up to the left hand side of the tire carrier. I could never get the SWR in check with the antenna on the right side while the Hi-Lift was attached.
Thanks!
That's perfect. I hadn't noticed the left-side version, they have about 10 different right-side ones.
