1 - 9 of 9 Posts
REF: Ultramount CB Antenna mount w/4' Firestick.
Did the tuning yesterday! SWR on Chan #1 was 1.5 and Chan 40 checked 0.5
This would seem to indicate that the antenna is a bit short? How would I lengthen the antenna, OR is this close enough?:confused:
Put a spring between the antenna and the mount, but that will lengthen it too much.
Actually SWR of 1.5 and down is fine.
X2 that SWR is just fine
If it is a Firestick II. The red cap comes off and there is a screw type tip to lengthen or shorten it. You could adjust it some but .5-1.5 range is pretty good unless you are running extra power.
Unless you have the model with the movable bolt on top, I think the only way to adjust is to trim the wire. Your SWR is great. Stop there.
Well...........
...........thanks folks :thumb: If .5 and 1.5 are good, I'll leave her alone :D
If it ain't broke, don't fix it :wavey:
Thanks so much for your time and help!
Granted it has been about 20 years since I studied Antenna theory but I don't believe it is possible to obtain a SWR of less than 1:1 and even obtaining 1:1 is very difficult/almost impossible outside of a lab setting.
What kind of a meter are you using that indicates a ratio of .5?
^ this is correct. The R in SWR stands for ratio. Ratio of power out to power returned. 1:1 means all power leaving the transmitter goes out the antenna. That's the best you can do.
Discussion Starter · #9 · (Edited)
It's a.........
Workman SWR-Meter SWR-2T
Now as per usual you folks here on WF have taught me a valuabe lesson: "Attention to detail" :thumb:
The lowest reading on the scale is "1". That means the readings on the lowest & hightest channel is: 1.2 and 1.5, which is ideal and I am OK :D PTL
Thanks for the time and help!
1 - 9 of 9 Posts
