Any ideas for a cb radio mount. Not sure how to mount my cb into my wrangler. I have a hardtop if that helps.
Can i see some pics of that? I think for what i want that sounds like it would work really goodTnDz TJ said:I have a Uniden 510XL.... small but powerful...
I took the easy way out since I have a soft top and virtually no security...
I used velcro on the mounting bar of the CB and a small strip on the center console next to the e-brake. I use a aux power source and a $3 plug.
When I don't use it, I pull it off and slide it under my seat to move it out of sight or remove it in 30 seconds by unscrewing the coax.
The power wire runs under my console under the pocket hole in the back under the dash...
Sure... Sorry for the glare. You loose one cup holder while in place. The wires run down between the drivers seat and tuck under the console. Perfect fit.. Just leave enough wire to pull forward and slide under you seat.brandon-99tj said:Can i see some pics of that? I think for what i want that sounds like it would work really good
Thanks!! That looks great, i think i'll run a similar setupTnDz TJ said:Sure... Sorry for the glare. You loose one cup holder while in place. The wires run down between the drivers seat and tuck under the console. Perfect fit.. Just leave enough wire to pull forward and slide under you seat.
The nice thing is angle lets the sound project up at you off the console.
