Hey guys here is a weird one. I have a DCC Taurus Efan controller that is wired directly to the battery (positive and neg.). I also have a blue sea fuse block that is wired directly to the battery (pos. only) via 4g with a 60amp inline fuse. The Cobra 29 is wired directly to the fuse block. The CB radio is mounted overhead to the roll cage. The DCC controller uses a temp sensor to only turn on at a certain temp, unless the AC is being used and it give the fan 50% power.
Whenever I hold in the mic button on the CB radio, the Efan will turn on, if it wasent allready on. I also have a set of HID hella's wired to the fuse block and there is no interferance with the fan if I turn the lights on. Anyone have an idea on how to fix this little issue?
