this code will be on for awhile then go out, then come back on. Randon misfires but it seems to be running fine 2001 TJ
Posted at Sun Sep 28, 2008 11:53 am
By rasmataz, Certified 2CarPros Master Technician
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible SolutionsIf there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
