I recently purchased a used 2017 JKU Sport which included a bumper mounted tire carrier. The previous owner had completely removed the third brake light including the wiring harness. I am swapping that out for a tub mounted carrier this weekend and I have an OEM brake light but not the wiring harness. Does anyone have a part number or know where I can purchase the wiring harness only? I have only found the complete light assembly for sale. Turns out that the third light is required here in TX starting this year.
No, it is not there. There is only the connector with nothing plugged in. I found the whole assembly on eBay for $35. Probably what they would charge for the harness if it was sold separately anyway.
You could just do some soldering and heat shrink tubing. I'd run some gasket maker in the grommet in the tailgate to make it watertight.
Sent from my SM-T550 using Tapatalk
