94 yj 4 cyl
my girlfriend snapped her centering pin (the bolt that holds the leafs together while also centering the rear axle on the leaf) it has the 35 in the rear so the pins head diameter will match that which is probably the same on all yj's. The jeep does have a 4 inch lift but i believe the stock centering pins are long enough to make it through the leafs or i can get longer ones and just cutt the exess off. what i'm looking for is the stock diameter and length of the bolt, and head so i know what to pick up at napa. i am away from the jeep now and dont have acess to the pin that is in there to get measurements off of. I'm an xj guy so many thanks from the other side.....-Josh
