Hi, anybody can answer:
Front Dana 30 and rear Dana 35, year 98:
What can I expect if I shane the ratio from 3,75 to 4,88? I am looking for shorter gears (it is stock 32RH trans.) and stronger acceleration.
Many thanks!
You gonna have to provide more info for a better answer
you engine? 4.0 6cylinder or the 2.5 4cylinder....or v8?
your current tire size and future tire size?
and your use and expectations out of the Jeep
all that info helps us give your the perfect answer.
and your current gears are problly 3:73
Knows a couple things...
Many thanks!
What size tires will you be running? With your 3-speed 32RH (which indicates you have the 4.0L engine), 4.88 would only be appropriate for 37" tires. 4.56 would be ideal for 35" tires, 4.10 is perfect for 33" tires. With your Dana 35c rear axle, I'd run nothing bigger than 33".
Thank you so much guys. I am looking for better acceleration and shorter gears on lengthy 3 speed auto 3 32RH. The usage of the Jeep is rather off road and city - no highway. Wrangler is my second car. I run only 32x11,5 Mt's (2,5 "lift).
That is why I question if this idea of regearing to 4,88 would be an insane change.
I expect the max speed up to 130km/h (80m/h) which is fine and approx 10% already ridiculous consumption:).
Correct?
