Can i replace a a tire size P225/75R15 currerntly on my jeep to a 265/70R16 with the rims attached
I had 31/10.50/15 when my jeep didn't have a lift on it and I'm guessing it shouldn't be a problem since a 265 is just a little bigger then a 31 I think..
Mostly old school..!
If running stock rims, you may or may not need to install a washer or two on each steering stop to prevent rubbing lower control arms at full lock, but that's no big deal, and other than that, they will be fine. Those tires would measure out to approximately 30.6" x 10.4".
