I purchased a rebuild kit for my 2000 tj's alternator, after installing all parts, it is not charging. I have read the stories about PCM rebuilds and how they don't last very long. I had the alternator checked at auto zone, they said it was bad, new parts now bad. I bought a junkyard alt. for a couple of bucks out of a dodge pick up, hooked it up, not charging. it was suggested that I ad an external voltage regulator, hooked it up with NEW parts alt. not charging so I do some srious checking into the situation and find a shorted field wiring , so a new part took out my PCM, destroyed an external voltage regulator. Advance auto to the rescue, one problem, at idle there is a fluctuation of about 1.5 volts. When I increase the engine speed the gauge gets pinned at 19 volts and check gages light comes on, actual voltage being produced is a constant high voltage of 16 -17 volts, too much for my liking. can anyone suggest a solution where idle voltage will be constant and higher RPM voltage will increase and decrease with load demand?
Feel like I've been doing the definition of insanity!
SO are you using the external VR?
Do you have good grounds for the external VR? I mean down to bare metal ground.
Did you use this kit or something very similar?
http://store.alternatorparts.com/hd-external-voltage-regulator-conversion-field-replacement-kit.aspx
What are your idle voltages?
Have you determined that there is an actual over charge with a multimeter?
Have you cleaned all the grounds, 3 of them in the engine compartment?
Have you cleaned the battery terminals?
Is your battery temp sensor good?
IS your battery good? TJ's are very picky about a good battery, not just working....Good condition
Reactions: trickydoc
Yes, using external VR. Good grounds for external VR.
Did not use the kit.
Idle voltages were 14.79 to 15.29vdc.
Grounds and battery terminals good and clean.
I did check the battery temp sensor using heat gun, seems to be working.
Battery is in good condition. has some age, but still good condition.
Where did you get the IGN source to excite the VR? it makes a difference.
I suggest the green/pink wire coming off the ASD relay in the PDC. That will be a clean source that will give you 14+/- volts. Many of the other places I've tried will put it an unacceptable volt range. Also check the ohms of the VR itself should be 1.75 - 1.76 this will tell you if the VR is set correctly and working properly to give you the 14 - 14.5 volts you need.
Let us know how this works for you.
test voltage regulatr ohms - Bing video
I did get my voltage from the green and pink wire, all seems to be good but , once in a while I get an overcharge when I put it in reverse, go forward most of the time . All suggested tests you mentioned are ok . I made sure of that.
Thank you for your help, much appreciated
