1 - 11 of 11 Posts
I bought my 2008 Wrangler X about a month ago. It's been great, drives great, etc. This morning I start her up and the check engine light comes on. It just hit 37K miles and it has had the oil changed and I checked it. Oil looks clean and is full. Any ideas of what it may be off the top of your heads? I drove to work which is only about 5 miles away and it drove fine. I'm going to take it by Advanced tonight and get them to scan the codes for me, but I just thought that maybe there was a scheduled maintenance or something that may have have caused it.
You don't need to bring your jeep somewhere, you can check the codes yourself.
*Insert the key into your ignition. Rotate it to the "On" position without starting the engine.
*Push inward on the key, and quickly rotate the key from the "On" position to the "Acc" position three times, ending in the "On" position.
*If you've done it correctly, all of the lights will light up and six dashes (- - - - - -) will appear on your odometer briefly.
*Write down any numbers that appear after the dashes. If no codes are stored, it will just read "-done-"
Easy :punk::punk:
^^^ nice i have an OBDII reader, and i'm buying another wireless monitoring one for my android but that is some good info right thar
Easy :punk::punk:
Does this apply to the 08 Liberty as well?
Thanks. My Liberty is an 08, I have a code reader, but I'll check it out w/o the reader.
The Bad Guy
A check engine light has nothing to do with your oil or any scheduled maintenance. It means that there is an issue with your emissions system.
1 - 11 of 11 Posts
