I got a 2012 four door wrangler with less than 7000 miles and my check engine light came WTF. Has anyone experienced a similar issue
check your gas cap... it might be loose... worse scenario... get somebody with a car scanner and see what is going on...
:punk:
You can see the code yourself if you cycle the key three times (don't start it) and leave it in the on position the last time. The ododmeter will show the code. If it's a 300, 302, 304 or 306 you probably have a bad head on the driver's side. It's a known issue and they'll replace it under warranty.
