1 - 12 of 12 Posts
Administrator
It sounds like you probably just muddied up your o2 sensors, but to check the code yourself turn your key to the on position,off,on,off then on. Wait a few seconds and the cel will begin to blink. count the blinks. there will be a pause between numbers. The check should end with the 55 code. You can also take to any autozone and they will check it for free.
How does one muddy up an o2 sensor seeing as how the part that sends the signal is completely in the exhaust?
1 - 12 of 12 Posts
