on my trans what i thought would be the plug you pull out to put oil in the trans mine says do not remove its on the drivers side about hlf way up on the trans
not that I would know/ and or be able to help you out, as I have been fortunate no leaks etc.-------but what is it you are driving? I had a friend who had a Jetta that never needed the tranny cracked open---- lifetime fluid...couldn't even figure out how to open it.
The Bad Guy
If it's a manual trans, you check it by pulling the fill plug.
