1 - 12 of 12 Posts
In this thread I'm going to compile links to; build threads with Chevy small block swaps, Chevy Lsx swaps, and threads that contain information for Chevy power train swaps. As well as the links to commonly used parts retailers.
These list are nowhere near complete, if you know of a thread, or useful part I've missed post it, use the same format if you can to keep things easy for people to search through.
Build threads
305tbi, Th400, Np241 -Kywaterman
http://www.wranglerforum.com/f330/89-yj-sbc-swap-build-thread-256560.html
350tbi, Ax15, Np231 -Cajon Yj
http://www.wranglerforum.com/f330/5-7-vortec-swap-242910.html
350 Carbed, Th350, Np231 -Scooby88
http://www.wranglerforum.com/f330/93-yj-slow-build-183485.html
350Tbi, 700r4, Np231 -TexasDemon84
http://www.wranglerforum.com/f330/my-350-build-224751.html
406 Carbed, 700r4, Np231 -bigboystoys
http://www.wranglerforum.com/f330/sbc-406-build-thread-253361.html
350 Carbed, 700r4, Np231 -sslopok
http://www.wranglerforum.com/f330/my-sbc-build-thread-251976.html
350 Carbed, 700r4, NP233 -mandng0
http://www.wranglerforum.com/f330/350-build-for-dummies-27066.html
350 Carbed, TH400, Np241 -Felsengleiskette
http://www.wranglerforum.com/f330/my-95-yj-chevy-swap-22098.html
350 Carbed, Th350, Np41 -Crashzx6r
http://www.wranglerforum.com/f118/yj-build-243696.html
4.3 Carbed, Nv3550, Np231 -Kruger (lots of info)
http://www.wranglerforum.com/f118/89-yj-with-4-3-vortec-191172.html
4.3 Carbed, AX15, Np231 - 1Sas (very detailed, Great Thread)
http://www.wranglerforum.com/f218/yj-v6-conversion-swap-121274.html
Lsx Swaps
6.0, Th350, Np231 -89JEEPYJ
http://www.wranglerforum.com/f330/v8-motor-swap-89-yj-build-144053-2.html
5.3, Nv4500, Np241 -JasonH28
http://www.wranglerforum.com/f330/lil-blue-an-89-yj-5-3-soa-monstaliner-build-174740-2.html
5.3, 700r4, Np231 - rausch42
http://www.wranglerforum.com/f330/jeep-5-3-build-250068.html
5.3, NV3550 -GeorgeC (This is in a TJ but could be helpful)
http://www.wranglerforum.com/f118/2000-tj-5-3lsx-wrangler-207537.html
LS3, AX15, Np231 -ELIMINATOR (In a TJ, but slick build)
http://www.wranglerforum.com/f118/ls3-376-480-jeep-conversion-133442.html
Information Threads
Radiator hose
http://www.wranglerforum.com/f330/yj-350-radiator-hose-help-630458.html
Fuel Line connector, TBI
http://www.wranglerforum.com/f330/sbc-fuel-line-connections-671889.html
Sm456, Chevy 4speed
http://www.wranglerforum.com/f330/sm465-question-613850.html
LsxRT intake usage
http://www.wranglerforum.com/f118/any-lsx-swaps-using-the-fast-lsxrt-intake-379186.html
Discussion on Fuel injection or carburetor
http://www.wranglerforum.com/f118/305-swap-242981.html
Novak Gm engine into Yj section
Chevrolet & GM Engine Conversions in the Jeep YJ Wrangler
Parts
Novak- Lots of conversion Parts, mounts and adapters
Novak Jeep Conversions - Home
Advance Adapters - Adapters, motor mounts, and various parts
AdvanceAdapters.com | Engine & Transmission Conversion Adapters - Advance Adapters
JB Conversions
- Slip yoke eliminators for Np241 (fullsize Chevy/Dodge transfer), Np231(Jeep, Chevy, Dodge) And various parts. Good people to deal with.
JB Conversions, Inc.
M.O.R.E - Weld in Motor mounts, high quality and heavy duty.
Jeep Motor Mounts YJ Wrangler Converting to Chevy V-8 (small or big block) engines from Mountain Off-Road (M.O.R.E.)
http://www.summitracing.com/parts/mre-jm400
Mountain Off-Road JM400 - M.O.R.E BombProof™ Motor Mounts in Bare Steel for 87-95 Jeep® Wrangler YJ with GM V8 - Quadratec
Gm Conversion Radiators
In order from cheapest to most expensive. Remember, sometimes with a higher price your just buying the name, yet at the same time, you get what you pay for..... I only included a few, these are the main ones I see people using.
Champion Cooling $210
Amazon.com: Champion CoolIng Systems, CC8102, 3 Row All Aluminum Replacement Radiator for Jeep Wrangler YJ *(Chevrolet Conversion): Automotive
Advance Adapters $415-$576
Radiators | Advance Adapters
Novak $589
Radiator for the Jeep YJ Wrangler with Chevy & GM Engines
The cheapest, and possibly best, route would be to use a universal GM radiator from one of the big three (Summit, Jegs, Speedway) BUT, they will not simply bolt in as these do, you would have to figure out a way to build mounts for it.
Another option would be to find a local radiator shop. Talk to them, tell them what your doing and see if they can custom make you something. Support the local man, it pays off in the long run.
LSx Wiring
There are several options when it comes to wiring a Ls motor. If you feel like putting in the time and looking to save a few bucks cutting down a factory Gm harness can be done. Many companies such as Painless make pre-made wiring harness'. Then there are new, custom harness that can be bought to fit your needs.
Store Bought and Custom Built
Painless.
Search Results | Painless Performance
http://www.summitracing.com/parts/prf-60217
Speedway
ls harness from Speedway Motors, America's Oldest Speed Shop
Performance System Integration PSI
PSI // Performance Systems Integration // 732.691.6531
Speartech
Speartech | LSX Harness | LSX Swap Harness | LSX Powertrain Packages | LSX Engine Packages | LS1 | LS2 | LS3 | LS7 | LSA | LS9 | Vortec | 58X | 24X
Howell
GM LS-Series Products :: Howell Engine Developments
BP Automotive -Personally know the guy, does great work. (custom Harness)
LS1 Swap | LS1 Wiring Harness | LS1 Rewire Service | BP-Automotive.com
Speed Scene Wiring
- custom harness
Automotive Wiring Harness | LS Fuel Injection Conversion – SSW
Current Performance Wiring -Custom Harness
Current Performance Wiring LT1, LT4, LS1, LS2, LS7 Engine Wiring Systems
Lsx4u - They modify factory harness and sell engines.
LSx4U.COM
Cutting Down a Factory Harness
This subject has literally TONS of info on the internet.
A thread on LS1tech is quite nice.
LS1 Swap FAQs - LS1TECH
That forum has a lot of other good information on it.
Thread on cutting down a harness- reno4x4 forum
LS Factory Harness to stand alone How To
A nice article published by GM High Tech Performance magazine
Custom Wiring Harness Build - GM High-Tech Performance Magazine
5.3 harness cut down and install in a Jeep
5.3L Chevy Motor Swap – Wiring Harness | In a Jeep
Tbi Performance
In this thread the guy is building a 350 Tbi, uses vortec heads and an LT1 cam. The motor was built with low end power in mind. All the posts are educated and seem like good solid information and advice. Covers various situations that arise while trying to modify a Tbi motor.
Cam for my 350 TBI truck - NastyZ28.com
I'm considering a 4.3 or 350 sb... I'm going to call Novak in the morning to see what I'm looking at cost wise
1 - 12 of 12 Posts
