Is shortening a front drive shaft out of a XJ something I could do? or do you need a machine shop? and if I cant do it, what kind of place do I need to take it to? Will new splines need cut into it?
That's not a home job, look in the yellow pages under Automobile Machine shop service, give one of them a call and they'll be able to direct you to someone that can do the work.
yep, gotta be cut, rewelded properly and balanced. usually has to go to an actual drive shaft shop.
Hacks off Parts while Lit
shouldnt need new splines unless you have insane amount of flex. mine twists up pretty good and the xj shaft shortened worked fine. if it doesnt have enough travel, you'll need a custom shaft built.
to cut down my xj shaft it seems like it was around 50 bucks. i got both my shafts done at drive shaft shops.
